snowhite
Hey guys' I got into a bind again with this sled again! I had replaced the bearing that's on the brake caliper and a new seal and flange, when I put this together I of course forgot to put the circlip on the shaft ! Ha, so when I had this apart I peened the shaft area where the bearing sits and also put some bearing retainer. Now to get that caliper off it's not happening as the bearing is really on the shaft. I see that they have a tool to remove this unit as there is no way to try to pry at the bearing any way! Any one have a picture of the tool or what have you done to get the unit off the axle? Thanks.
Its a bitch and reason why I never used Loctite again.
https://ty4stroke.com/threads/loctite-the-driveshaft-they-said.147135/
swampcat
Heat from a heatgun. Be careful if using a flame.
snowhite
Yaa I got the dam thing off! Found a 2 claw puller that fit in there and worked the bearing /brake caliper off. That bearing retainer stuff works great! So I did dimple the shaft a bit more just so that bearing wouldn't spin.
