Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
I started the Phazer and let it warm up. The high beam indicator was lit and would not turn off. I tested the switch at the connector using a continuing tester by the clutch and it tested OK. I checked the headlights fuse and its OK. I disconnected the battery hoping it would reset but no change.
I took off the headlights and nothing seemed out of order. What else should I be looking for? Is there a relay for the brights?
I ran the Phazer a few weeks ago and the high beam indicator was not on.
I had trouble starting it today but I put it on the battery charger and it started right up.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I'd say it's the relay stuck to high but to be sure, pull the relay and see if the signal supplied to it changes with the switch.
Cubby
- Dec 14, 2009
Thanks Mooseman. That will be my plan this weekend. I wished the relays were labeled. Wouldn't you know it - its plus 1 today and then by the weekend it will be mid - 20 C. It will be cold working in the garage!
Cubby
- Dec 14, 2009
It was the relay. Unpluggged it and started the sled. No ligths. Plugged the relay back in and the lights work properly. Since its a pain to get at I'm just going to get a new relay.
Cubby
- Dec 14, 2009
Turns out it wasn't the relay after all. There were 2 broken wires in the headlight harness on the right side.
When I had the headlight out the high beams went out - when I re-attached the headlights the high beams went on.
I cut and resoldered all three wires on the right side (and lengthened them). Hardest part was taking off the 10 year old electrical tape to get to the wires. And of course it was -25 outside but the garage was a little warmer.
