twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have been running all Thunder Products Clutching since my 17 LTX SE had 350 miles on it with a TD Power Trail tune. This past weekend while out riding I found that all 3 of my TP secondary rollers were gone and that had gouged out my Dalton 33/35 helix. There is about 4000 miles on the rollers. They looked good before this last trip.
What could cause all 3 to break? Everything has been great up to this point.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
They obviously are not up to the task and strong enough, they get old, brittle and then break, I've seen these broken and MIA in the past. Replace them with Hi-Torque rollers and replace the helix while your at it.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The Hi-Torque ones last longer without breaking? I see that they are different material than the TP ones. What are the stainless washers for that come with them? For shimming one side of the roller or something?
RAMSOMAIR
Yes, thin washer is a shim for the thrust side.
KnappAttack
- Feb 19, 2004
- Welch MN
Absolutely stronger and better, easier rolling. I've only ever seen one Hi-Torque Roller fail, and it didn't completely fail, but just delaminated due to an improperly cut helix on a ski-doo.
That thrust washer is nice as the stock rollers especially start to wear into the casting.
KnappAttack
- Feb 19, 2004
- Welch MN
I've also seen that steel washer grind/wear right into the casting on the winders too with miles.
I have had good luck with the OEM late model rollers. I started out with the TP rollers when the sled was new but I went back to the OEM ones around 4000 miles ago and they still look good.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Did you have an issue with the TP rollers?I have had good luck with the OEM late model rollers. I started out with the TP rollers when the sled was new but I went back to the OEM ones around 4000 miles ago and they still look good.
Not a real problem but seemed to be getting a little wobbly on the pin. I kept them as spares.Did you have an issue with the TP rollers?
What's the solution then? Just replace the whole sheave half in time?I've also seen that steel washer grind/wear right into the casting on the winders too with miles.
The stock rollers wear into that the most I find.
I usually use the hi-torque kit, but there are many that I've switched out to the stock Cat rollers.
