ttocs2
- Jun 16, 2004
I have had a problem with my Bruin a couple of times that I hope someone here can help me with. I was in mud, spinning, trying to get out, and my Bruin started cutting out, acting like it was out of gas.. It has done this to me 3 times, and all 3 times it was when I was spinning in mud.. After I finally get out of the mud, and give it some gas to drive a little bit, it straightens out and runs fine... But I have never had it do it while trail riding, or anything. Any ideas on what may be causing this?
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
cuttin out
have you checked the fuel line for kinks ect.? i thought i saw earlier post bout a rev limiter. try a colder plug too or put a platnum one in it
ttocs2
- Jun 16, 2004
Is it possible this is like a vapor lock problem that I see some people experience with grizzly's??? The mudhole I play in when this happens is a big mudhole with a lot of water, so there is usually steam from the water, just wondering if that could cause the gas to get hot enough to cause vapor lock?
![](/styles/admin.gif)
I would guess you are getting the plug wet....try some dialectric grease on the plug boot and then coat the coil and plug wire with silicone spray.
