uofm
Could anybody tell me what the gearing will be in this compared to the XTX 141 or XTX 137?
veemaks
- Jan 31, 2009
- Sweden
- Sweden
- Sidewinder BTX LE -2017
CR gave the info in his blog. Basically it will be the same gearing if you're not getting the XTX LE with 2.25 Power claw.
"RTX and LTX 129 / 137 inch track, XTX and BTX 141 x 1.6 /153 x 1.75 all use 9T drivers with 21/41 gear ratios. XTX and BTX x 2.25 Power Claw uses 8 tooth drivers with 24/50 cogs and the MTX uses 7 tooth driver with 21/49 gears.
I’ll save you the math and give theoretical tops speeds for these ratio formulas: 21/41 9T = 120mph / 24/50 8T = 105mph and 21/49 7T = 82mph."
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
But then he gives the over drive ratio of .91. That would make the top speeds at full shift 131, 115 and 90.CR gave the info in his blog. Basically it will be the same gearing if you're not getting the XTX LE with 2.25 Power claw.
- Apr 14, 2003
- Hessel, Michigan
I would think the XTX with the 1.6 lug 3.0 pitch track would be 8 tooth drivers like what I have now.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
at what rpm? Im coming up with less then 131 for rtx at .91OD.But then he gives the over drive ratio of .91. That would make the top speeds at full shift 131, 115 and 90.
Dan
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
I was just dividing the speeds given by .91. CR says they've been seeing mid 120s in testingat what rpm? Im coming up with less then 131 for rtx at .91OD.
Dan
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Running the numbers at .91 and 8800 rpm is 120 and some change. Must be shifting out more than they expected.
DC5
Or running more rpm, at 9100 it is good for 125mphRunning the numbers at .91 and 8800 rpm is 120 and some change. Must be shifting out more than they expected.
- 30K
