		Dan Lance
- Mar 5, 2019
- Eagle River Ak
- nytro,apex,summit,rs vneture,phazer
Yamaha was way more efficient with their use of space on the sleds they built. There's crazy room all around this motor in this chassis. I dont see why an Apex motor wouldn't fit. The water outlet on the tunnel cooler might need moved for header clearance. Wont know till you go
		mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
Git r dunHmmm that means an Apex engine would drop in…. I have a sidewinder with no motor and a spare apex engine…
Nikolai
CR Racing makes a kit to put the Apex motor in the sidewinder.Hmmm that means an Apex engine would drop in…. I have a sidewinder with no motor and a spare apex engine…
				Viper/Apex Billet Engine Mounting Kit
Viper/Apex Billet Engine Mounting Kit This kit allows you to put an Apex motor in a Viper Utilizing the Yamaha Nytro components such as driveshaft, jack shaft, chaincase and heat exchanger. The heat exchanger is modified to work with this kit and a core must be supplied. This kit allows you to...
					crracingcanada.com
			Nikolai
Cool project Dan!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Great job Dan! Now I understand why all your supercharger parts were for sale!Yamaha was way more efficient with their use of space on the sleds they built. There's crazy room all around this motor in this chassis. I dont see why an Apex motor wouldn't fit. The water outlet on the tunnel cooler might need moved for header clearance. Wont know till you go
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
 + other gooodies
- Uxbridge ON
Doooo it!!!!!!!!!!Hmmm that means an Apex engine would drop in…. I have a sidewinder with no motor and a spare apex engine…
The apex motor does fit perfect in the sidewinder.  the one back motormount tab closest to the chaincase needs to be cut then the motor will drop right into the back mount (use the apex rear bolt shortened, sidewinder one is too short), for the front the spacing is the same, you just need to weld ears to the existing front mounts as they are lower.  sit the front of the engine just off the front frame and your clutch alignment is dead on.  im making a thread on this build now.
		kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Wait you are calling this a nytwinder but there is no Nytro here, its a viper or no?
		Dan Lance
- Mar 5, 2019
- Eagle River Ak
Read the very first sentence of the thread
		kinger
- Jan 17, 2005
- Clear Lake, IA
LOL I did 35 times, dang I think I am getting dumber....I get it now.Read the very first sentence of the thread
Sweet build! What's on tap for changes for this year?
		Dan Lance
- Mar 5, 2019
- Eagle River Ak
J&S knock control ( just in case type of thing).  Test different skis. Revise turbo inlet ducting. Rear shock testing.
			are the inner tunnel braces part of the bumper kit or where did you get those?Started on the rear bumper and running boards. These parts came from CRracing. Coolant for the air to water intercooler will run through these. Inner tunnel braces and exterior braces installed.
		Dan Lance
- Mar 5, 2019
- Eagle River Ak
				2014-21 Yamaha Viper/Sidewinder Upper Tunnel Stiffener | CR Racing
Our Cr racing 2014-21 Yamaha Viper/Sidewinder Upper Tunnel stiffeners are designed to help strengthen the stock tunnel for purposes such as hauling extra fuel/gear.These plates are designed to tie into the CR tunnel Stiffener/bumper kits or may be used by themselves.We have predrilled holes to...
		Dan Lance
- Mar 5, 2019
- Eagle River Ak
Well ripped the left side suspension off. Hit a rock wall. Did ride it out to the parking lot though
		Dan Lance
- Mar 5, 2019
- Eagle River Ak
Busted parts
				 C2DD3768-9A59-4476-AB38-DD06246AAD45.jpeg67.4 KB · Views: 155 C2DD3768-9A59-4476-AB38-DD06246AAD45.jpeg67.4 KB · Views: 155
				 61FCDD2B-40D4-4ECF-9734-71E99C3BC414.jpeg68.6 KB · Views: 141 61FCDD2B-40D4-4ECF-9734-71E99C3BC414.jpeg68.6 KB · Views: 141
				 6101C4E4-E04E-4453-B988-E8244BA4D439.jpeg47.2 KB · Views: 148 6101C4E4-E04E-4453-B988-E8244BA4D439.jpeg47.2 KB · Views: 148
				 6F841A2F-5993-45F2-8D7E-AE72CE90A0AB.jpeg39.7 KB · Views: 152 6F841A2F-5993-45F2-8D7E-AE72CE90A0AB.jpeg39.7 KB · Views: 152
				 047E5187-A3AF-46AA-848E-1CEEBBABDB86.jpeg92.9 KB · Views: 156 047E5187-A3AF-46AA-848E-1CEEBBABDB86.jpeg92.9 KB · Views: 156
- 12K
