LABRADOR WARRIOR
- Jan 26, 2006
- Churchill Falls ,NL
- 2015 Viper MTX
I just finished installing the A arm bushings (next to bulkhead) and I found that the arms still have some play in them..Is this supposed to be there???The movement is front to back
Anyone else experience this after a bushing install???
Mike
Anyone else experience this after a bushing install???Mike
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Using stock OEM bushings? If so that is common.
LABRADOR WARRIOR
- Jan 26, 2006
- 2015 Viper MTX
bushing
Yes
I'm using oem bushings
thanks
mike
Yes
thanks
mike
Len Todd
Take one of the cupped nylon washers and sand off the cup and make it thin enough to just take out the slop. Install it between the A-Arm and Bulkhead bushings.
LABRADOR WARRIOR said:I just finished installing the A arm bushings (next to bulkhead) and I found that the arms still have some play in them..Is this supposed to be there???The movement is front to backAnyone else experience this after a bushing install???
Mike
I just did mine too. but I didnt notice any movement. But I do still feel a little tap tap when I hit smaller bumps just right and Im not sure what it is??
