rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
The base number is the octane required to run it in stock form. Whatever the user manual says.
If you want to mix pump with race always use the highest octane pump fuel you can get hold of.
At altitude you will need less octane because of the atmospheric pressure beeing lower reducing the compression pressure. The air will also hold less oxygene thus the need for running a leaner mix at altitude. If you're safe at sealevel 0 ft elevation, your will only get safer the highet the altitude.
SLEDSTART
Thanks for the reply!
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Calc not working... Is there an updated link?
the site no longer exists. I found this.
or even better this one
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I have the Excel spreadsheet saved locally if anyone needs it.
Site should allow it to be uploaded.I have the Excel spreadsheet saved locally if anyone needs it.
kinger
- Jan 17, 2005
- Clear Lake, IA
Lets see...
Nope doesn't like the xls file format.
I have posted them before. How big is it?Lets see...
Try now! I think I fixed it.Lets see...
kinger
- Jan 17, 2005
- Clear Lake, IA
Awesome!!Nice! It worked!
For those searching this for the first time, this is one of the most helpful tools when planning a boosted build AND how much octane you need. I have found it extremely accurate over the years playing with boost.
- 18K
- 7K
