TurboKeith
Try out this boost, octane, and horsepower calculator that I threw together.
Let me know if it looks pretty consistent with what you've found.
Updated 10-15-07 with the Nytro info and a cam timing lobe center calculator.
boost calc
boost calc
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Awsome, seems to be quite accurate, GREAT JOB.
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
Thanks for the effort.
Puts an end to the bullshit sessions on how much hp everyone supposedly makes! :ORC
Puts an end to the bullshit sessions on how much hp everyone supposedly makes! :ORCThanks!
TurboKeith
Disclaimer: These are theoretic horsepower and octane numbers. Every application is different. It does not account for thermal issues related to boost, turbo size, or ignition timing and how they effect octane requirements. Be conservative and add a couple octane points to the figures shown.
spray25
Great calculator.
TurboKeith
calculator update
The file in the first post has been updated to calculate compression ratios with various head gasket/piston combo's.
Re: calculator update
You got a sticky too! Congratulations Only the really good posts gets a sticky!
slacker said:The file in the first post has been updated to calculate compression ratios with various head gasket/piston combo's.
spray25
Hey I was the one that asked Tom to make it a sticky do I get a brownie buton or something?
Sled Dog said:slacker said:The file in the first post has been updated to calculate compression ratios with various head gasket/piston combo's.
You got a sticky too! Congratulations Only the really good posts gets a sticky!![]()
TurboKeith
Thanks fella's. I hope you can get some value out of it.
Jack_Shaft
The other elements have been posted before, but you're the first person to step up with an octane calculator, right on!
FastAction
is there an microsoft xls plugin so I can view it. I don`t have or need excel.
Jack_Shaft
FastAction said:is there an microsoft xls plugin so I can view it. I don`t have or need excel.
View it???
You need to plug in your numbers for it to work for yours or others' situations, so yes, yo do need Excel if you want to use this program.
If you want to use a free program to manipulate it, you can go to www.openoffice.org and download Open Office Suite - it's very much like a certain Microsoft suite out there, but it's free. It has a program that is very similar to Excel and is fully compatible with the .xls format.
Hope you have high-speed, it's a big D/L.
TurboKeith
I threw in a couple more updates to the calculator. It now does dynamic compression calculation that incorporates cam timing changes. It also has a calculator to determine cam timing changes in relation to head gasket thickness.
Right on man one question could you lock up the cells that we should not be using anyway and just leave the ones we need to plug data into open so we dont screw up our copy. Thanks
- 18K
- 8K
