Can someone help me?
asti
I need, at least i think so, copper donuts for my mp. They dont seem to sell them here in sweden, but i read that some of you have installed them. Where can i find them?
Second, there is a HUGE slop in my steering. I have changed things in the lower spindle, threw away some plastic/steelcrap and replaced with bearings.
It got better, but everything else seems loose too.
Skis definetily needs care, perhaps upper spindle.
Any suggestions of what to buy?
UPbushman seem to have a kit, will this cure my sled?
Thanks in advance!
I saw that bearing kit you put in and UpBushman's is basically for the same location instead of the plastic junk.
Check the inner and outer tie rods, then the linkages. For the inners and one of the linkages, I used the ones listed in this thread. Worked out great:
http://www.ty4stroke.com/threads/phazer-tierod-inner-end-upgrade.93662/
There is also the steering shaft block but that would just give fore and aft looseness in the shaft. That can be fixed by replacing the plastic blocks with these:
http://oftracing.com/OnlineStore15/index.php?main_page=product_info&products_id=93
It could also be the dog bone link from the steering shaft to the pivot. I used some heim joints but have had a partial success with them. The ones I put on my MP are still good but on my son's Phazer, they are worn and loose again. Both were installed at the same time but my son rides his more.
http://www.ty4stroke.com/threads/steering-arm.122513/
Thank you, both!
Hopefully they will ship the copper donuts to sweden.
$60 for shipping outside North America is insane! Check with Sledtoyz. I'm sure he would be much more reasonable.
Check with Sledtoyz, but if I remember correct I asked the one on ebay if he could do anything on the shipping and he lowered it to $30.
I have sent two emails to sledtoyz, but no response.
Do they normally take long to answer?
Shouldn't be but he is a sledder like the rest of us so he might be riding or just busy. Try sending a PM to Crewchief47. He's the boss/owner of Sledtoyz.
Things are good now, probably an email just disappeared!
Copper donuts are on the way!
