Can't get driveshaft out
There's a thread on TY site on this. Some guys had to build a puller to use once they split caliper and got brake rotor off. The puller bolts go into the same threaded holes that mount the inner caliper piece to the tunnel.
Still gonna need some beer!
Thanks for this, I'm hoping if I can get the caliper off the bearing I can pull it with one of my pullers.
I agree put gear back on then split caliper. It’s the disc that holding you up unless someone Loctited the bearing. If it’s just the disc and there is some movement in and out with hand just lube like Clutchmaster said and keep working it by hand in and out. A burr forms on splines along with rust and you are working that off. But whatever you do pull straight it can get cocked and the be a big issue even with a pulled.
The disc is loose on the shaft, I'm really suprised its not coming off. I'm drilling out the lower panel to open things up more. I'll update as I progress. Thanks cannon.
What's the little washer/clip thing for? It looks like it's beat up. My driveshaft is shot bigtime. Bearing is fine. There's so much play I can't believe I didn't have vibration.
Better pic
I don't see it here.
There’s no clip there, just worn and a sliver of steel has worn there. There’s a relief cut in the shaft there but no clip goes there.
Yea your gonna need a new driveshaft unfortunately :(
To do it right you’ll need to use one of the fixes. The set screw deal is probably best but I just used locktight on mine.
Yikes!!! that shaft is fawked!! How many miles?
