Strange problem.
'07 Apex mtn. custom built kit using a impulse header, gt28rs turbo(internal wastegate), custom built intercooler & piping, Hallman pro rx boost controller 3 stacked stock head gaskets & arp studs.
Here's the deal. I live in WI, ie. low elevation. When I run the sled back home or in the U.P. the lowest I can get my boost is 12psi. This is with either the boost controller removed from the line to the wastegate(ie wastedgate line running str to the boost source) or with the boost controller setup and turned all the way out. 12psi is as low as it goes. I haven't tried to turn it up from there because I run it on pump gas and thats my limit.
When I ride out West, 9000+ft elevation: If I don't change anything from my settings back home sled will make about 6-7 out of the gate. If I put the heavy spring in the Hallman boost controller and crank it all the way down the absolute most I can get out of it is 10-11 psi sometimes, but usually it falls off to 8-9psi. This is with the boost controller cranked all the way in.
Is this normal? Doesn't seem like it to me.
Im my eyes it should make the same about of boost, its just the turbo will be spinning faster to do it.
I have done a boost leak test. It checks out good, no leaks. While doing the test I can verify that the wastegate actuator is working properly. It crack open at about 11psi and goes further from there. I have the actuator off the sled right now and test it in my hand, same thing, it seems to operate correctly without leaks.
What gives? Any idea?
