gregdec1
Has anyone though about or installed a muffler from a car on their Nytro? I was wondering if it would work or not and what it would sound like. Im thinking of like a magnaflow muffler or something. Any thoughts or ideas?
bottlerocket
Schmidt bros can is a car application as I found the same thing on ebay before they mod it to fit.
NFLD-Nytro
I've used a Cherrybomb on my Nytro. It need a restrictor welded on the end, but sounds fantastic, though it's obnoxiously loud.
A cheap muffler off a 4 cyl car would work fine if you're looking for a replacement for the stock unit, and would probably be quite a bit lighter.
natedawgedog
I have a Cherry Bomb Turbo muffler undertunnel setup on my xtx and I didnt need a restrictor on it, but I have pc5 w/autotune on my sled also. I think it sounds great, loud but not as loud as an MBRP muffler. plus it was only $35.
hearnoevil
D and D slip on, on mine, everyone loves the sound. Only costed me 100 bucks thanks to this forum
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
I put a magnaflow muffler on my nytro xtx and made it fit in the stock location worked out great and sounds awesome.
LSXM3
i also used a magnaflow for an under tunnel set up!
dansranger
I tried several and all were louder than my hauck husher.
SSX600
- Feb 13, 2010
http://www.youtube.com/watch?v=vsz4zx7W ... e=youtu.be
Check out this video its the magnaflow muffler I put on my nytro xtx
PETETY1968
- Jun 7, 2022
- FLINT
- 2009 Yamaha NYTRO XTX
2998 ARCTIC CAT F1000
2007 YAMAHA VECTOR
What model Magnaflow did you use on your seld?
PETETY1968
- Jun 7, 2022
- FLINT
2007 YAMAHA VECTOR
Also where did you find that awesome side to side crossing taillight you install on your video?
Pmtg04
I use this muffler. It's not loud in my helmet, whereas another I tried was. I'm happy with it for what it is and what it costs. It was to replace the factory, not necessarily improve. But it is lighter, but who knows how long it'll last. Going on my 3rd season this year with it, though.
PETETY1968
- Jun 7, 2022
- FLINT
2007 YAMAHA VECTOR
Thank you, I was able to find a muffler at O-Reilly auto parts near me, I had to use a hanger at the end of the muffler system to take some weight off the total system and I also made or use a support under the muffler supporting the muffler itself so not to fatigue the the collector at the engine as well I (my engineering degree at work) riveted the stainless band on each side with a rubber insulator against the tunnel not against the muffler itself. i think the muffler was about $54 dollars and I had to buy a clamp, and muffler joint sealant (a must). Overall I am happy with the set up I will see how the noise level is once the snow hits and I am ridding it.
