Cat Skis
JDKRXW
Saskatoon, Canada
Does anyone know if Cat mountain ski / saddle will fit an RX spindle??
I've got an old pair and they look to be very close.
Saddles are the same width (cats are shorter though). I am not sure about distance from center of mounting bolt to bottom of runner.
Best way to see if skis will fit is take the skis off the target sled, put the replacement skis under it, and see what (if anything) needs to be modified.
This weekend I grafted a pair of RX1 skis onto an Exciter. Plenty of modification required. Had to cut a rectangular hole in the bottom of the saddle to fit the TSS end, had to pull out the plugs from the pivot and cut out new plugs with holes drilled far off center (to raise the connection point), and had to add spacers (since the RX1 saddle is naturally too wide for Exciter).
My advice: *make* it fit!
