boardmandan
- Jan 15, 2013
- Waterford, MI
- ZR9000, Nytro XTX - Gone, Viper RTX-DX - Gone
Took apart chaincase and noticed notches in the mounting post that holds the chain tensioner. I can't tell from any pics I've seen if this is by design or if the tensioner is wearing into the metal. I've got about 7000 miles. Anybody else notice this?
beanie
- Jun 11, 2005
yup mine is same wayTook apart chaincase and noticed notches in the mounting post that holds the chain tensioner. I can't tell from any pics I've seen if this is by design or if the tensioner is wearing into the metal. I've got about 7000 miles. Anybody else notice this?
View attachment 172323View attachment 172324
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Precision has a brass bushing for that along with their new tensioner
REDLINE 1
HD TENSIONNER AND SKATE - 998T
Do you already know the PEFI Chain Skate? This essential upgrade which makes your Arctic Cat or Yamaha so reliable? Please welcome the PEFI Heavy Duty Tensioner; an addition to the PEFI Skate that revolutionizes the efficiency and allows the easiest chain tensioner adjustment. The HD Tensioner...
precisionefi.com
DooZ
Adds weight to your pile tho....lolMine was doing the same thing. I put the Pefi tensioner on. Very nice part , quality made a little overkill and pricey. U really only need a bronze bushing and steel sleeve on the stock tensioner. One of members on this site made one I recently lost access to my lathe otherwise I would have made my ownHD TENSIONNER AND SKATE - 998T
Do you already know the PEFI Chain Skate? This essential upgrade which makes your Arctic Cat or Yamaha so reliable? Please welcome the PEFI Heavy Duty Tensioner; an addition to the PEFI Skate that revolutionizes the efficiency and allows the easiest chain tensioner adjustment. The HD Tensioner...precisionefi.com
stgdz
- Mar 27, 2021
- Buffalo MN
Can't you just drill out the tensioner and put an oil lite flange bushing in there?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Sounds like that would be a easy fix.. Just need someone to make that? TRAVIS !! BOP?Can't you just drill out the tensioner and put an oil lite flange bushing in there?
stgdz
- Mar 27, 2021
- Buffalo MN
Why not just order it from McMaster?Sounds like that would be a easy fix.. Just need someone to make that? TRAVIS !! BOP?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Sure could.. Just press it in? What size we need?Why not just order it from McMaster?
stgdz
- Mar 27, 2021
- Buffalo MN
Mines not yet on the stand yet but will probably be in a month.Sure could.. Just press it in? What size we need?
You would have to figure out the id size of the spring that is inside the tensioner. Maybe two flange bushings with the flange on the inside of the sheet metal.
I would have to noodle on it but it may require a stepped bushing.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The area of tensioner mount in the chaincase is tapered.
These are not accurate measurements to go off for making a sleeve. But just to show the taper.
Brand new chaincase....
earthling
Stepped bushing will deal with taper.
REDLINE 1
The carbon fiber running board rails and lithium battery make up for that lolAdds weight to your pile tho....lol
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
stgdz
- Mar 27, 2021
- Buffalo MN
Any alternatives without dropping the $300 bones on the pefi fix and skate?
- 36K
