Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
perhaps same as 7000
jdinny
9000-7000 same deal
Nytro40th
- Sep 19, 2007
Did cat change the chaincase gears and chain?
Oh you should post your location site rules.
jdinny
10-4 on the location, done.
Cat switched supplier's on those parts hopefully to better quality.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
What I understand from the sled show is that the 2014 Cat and the Viper chain case is the EXACT same, they both have updates, the same updates for the coming year. I asked this question directly to the rep.
What the exact changes are I don't know, I have not seen the cat's chain case in the previous year so i can not comment on that..
09nytro
I do know you can get gears and a chain from TEAM ...and take the reverse out....that's what I'm looking at doing and putting a different tensioner in it
09nytro
Well I put about 3000 in to my nytro and counting.....so what ever it takes
I would not lose reverse to try aftermarket. Trust me. Since the Cat updates to chain case there is very little issue.
09nytro
I hear you !
It's just an option if I have to.....I always gear down anyways to get more on bottom
I have 20/40 in my nytro right now ,I will get my buddies apex out of the hole about 1/2 sled till 60 then he is gone
But I really don't care about going fast.....
jdinny
I have never had a reverse issue in 3700 miles
In 2013 Cat changed the mechanism used to shift the chaincase into reverse. Mainly they made the fork have constant engagement with the stepper motor that shifts it by adding more teeth to the fork. What they did changed the way the reverse mechanism works for the better. This solved most issues. If Yamaha adds a delay to what Cat already did it should be a good design. There are 3d pics of what they did if you do a search.
Alatalo
Redesigned for 2013 or not, there was still a recall to change the shift fork on some 2013 models.
http://www.arcticchat.com/forum/cat-ser ... sleds.html
Evil rumours indicate they ran out of redesigned parts and had to use 2012 parts to finish the 2013 sleds...The affected sleds were then recalled once they got more redesigned parts. Don't know if this is true.
How does that have anything to do with the Viper which is 2014?
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
The problem goes back to the design. Second set of gears second chain adds weight/rotating mass and completely unnessasary complexity, a very poor design. Cat, Yamaha and everyone else have or had reverse systems that worked without issue. Just use a good stepper/servo motor. That system worked in the automotive industry, all our 4x4s use it on the transfer case and it works, (no second set of chain and gears). ENGINEERS NEVER MAKE MISTAKES, THEY ONLY MAKE REVISIONS.
Alatalo
It doesn't. You are the one that started dropping details about the redesigns Cat did for 2013, so I assumed it was OK to fill in...?cannondale27 said:How does that have anything to do with the Viper which is 2014?
