I tried... No room to get your hands or even one hand to fit in there, there's a coolant hose that takes up too much space. I bielieve its doable on the Viper, there's no hose under the motor on the Viper.
t50 torx bolts out to remove muffler. The 3/8" drv t50 came from Harbor Freight and used drive pin to remove the bit. No heat was required and bent an old allen wrench for spring removal
