scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
I just torqued mine down per the manual at 12 lb ft and 3 of them stripped. I'm beyond mad at this point.... I'm guessing that means I need a new chaincase?
Pstn head
How about Heli coils ?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Depending on location you could drill them out and use a bolt
too late now but I run a die over all the bolts and tap the holes to clean out the loctite. Having old loctite in them when re tightening makes it tough to feel the threads. It’s delicate work. Sorry to hear the threads gave out
Ms
Ms
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
UPDATE: I used my snap on tap and die set to clean out all the threads. I replaced the damaged screws and put it all back together and got everything torqued down to 10 lb ft..... I didn't dare go to 12.... What's everyone's thoughts on that? Hope that's ok. 12 seems like a lot for these screws.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
I dont torque the chaincase bolts, just do it by feel. I have heard of a few people stripping them at 12 ft lbs.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
I'm wth Big_Phil. Set my expensive digital torque wrench on 10lb. and broke the screw. Must stretch when retightening every year. Got it extracted but a bit of a pia. New screws and and went by feel.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Just did mine today third time it’s been apart 12 ft # on a snap on 3/8 drive no problems
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I always use an inch lb torque wrench for anything 20 lbs and under! They are more accurate imo
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
Yes, I was using an IN LB torque wrench.... Just did the conversion from LB FT to IN LB.
Moodeyblue
- Sep 16, 2003
- Alberta
- Sidewinder SE
I broke 1 screw yesterday at 12 ft lbs. and felt another one start to yield. Luckily I was able to get the broken screw out easily.
I will either go to cap screws or torque by feel. Very discouraged also.
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
What's everyone's thoughts about using blue locktite and only torquing to 8 ft lbs?
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
I've broke two heads off and was fortunate to have to have enoough thread to back them out. Have to make sure both threads are absolutely dry and void of any oil or they will easily strip. I also agree with the inch pounds torque setting and set it at 138 inch pounds (11-1/2 foot pounds) and check "hand-tight" after and then again after first ride.Yes, I was using an IN LB torque wrench.... Just did the conversion from LB FT to IN LB.
I have stretched the screws before at 12 ft-lbs, I have now done several cases with an in-lbs and dont go over or 100 in-lbs. You can see the cover is seated metal to metal on the flanges so going over is a waste and a little blue loctite will not hurt.
