slimjim2525
Well I lost all the oil in the chaincase. Heard the chain going over the top gear, and new there was obviously something wrong. Opened the chaincase, and it looked like burnt toast. Not a drop of oil. I initially thought it was a chaincase seal but it was not. The bottom bolt on the cover has a hairline crack in it. I only found this after I put it all back together and saw it leaking in my garage. I ended up putting RTV on the inside groove where the gasket sits, and JB weld on the outside. Hopefully that works, but this is now my backup sled, as I just ordered a 2022 LTX-GT. I hit a huge G-out in Maine and broke the sway bar, so I'm thinking this was caused then, and started to leak fluid, as I has 1900 miles on the sled before I heard the grinding. Can't get a new cover for nothing, thanks to Covid. Good news is, the BOP driveshaft wedge worked great. 4K miles on the sled this year, and the shaft only had .005 wear. Bad part is, I should have bought the chaincase protector from BOP, and I would have saved myself 8 hours work, and a 1K bucks. Pics to come.
slimjim2525
slimjim2525
Do yourself a favor. Order the chaincase protector from BOP's. I didn't think I would ever need it as I only ride groomed trails, and here we are.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Ouch, sure looks like that bottom tab took a hit.
Kudos for taking the blame and not blaming "Cat DNA"
I might add the chain case protector to my new LTX after seeing this.
slimjim2525
This sled really has been rock solid. 10,665 miles on it. This was not a sled failure, but a pure #*$&@ luck bad g-out section of trail. I put all the aftermarket fixes in, and its solid. DMC upper gear, welded tensioner, driveshaft wedge, tunnel savers, BOP relays. No blown belts, hell haven't done a thing to the primary or secondary clutches except clean them.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Tough break...
I ran the BOP protector on my Sidewinder. Good investment
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
What is a g-out? A big bump and you bottom out the front and broke the sway bar? Trying to understand how it can break the chain case.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Yes a g-out is a big hole or washout in the trail, when he bottomed out he hit the very bottom of the chaincase & cracked the mounting ear causing the fluid to leak outWhat is a g-out? A big bump and you bottom out the front and broke the sway bar? Trying to understand how it can break the chain case.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
G-out >You see them on grade trails(straight) trails that have small bridges.. So the trail narrows and sleds are forced to ride the center of the bridge and you get a spot (always) deep hole. Usually bad to hit these while going to fast.. Probably other areas these form on trails, but that's where I see them
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Oh I see. Is it Procross thing when you bottom out the front it hits underneath? I bottom out plenty of time in my Apex when shocks were due for rebuild one trip. Out with the boys so had to finish it regardless. I was younger, naive and my back could take it. Never damaged anything other than me ego.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
The chain case hangs lower so its possible
