mr. bwok
- Nov 22, 2016
- toronto
- 2017 sr viper ltx
- Marmora
In my wife's Venom there seemed to be a bit more metallic contamination while doing chaincase oil change than i was expecting. The chaincase oil appeared pretty shimmery with metal. Has anyone else had the same experience?
Another one that maybe @cannondale27 could help on.In my wife's Venom there seemed to be a bit more metallic contamination while doing chaincase oil change than i was expecting. The chaincase oil appeared pretty shimmery with metal. Has anyone else had the same experience?
Mine was also. I think its normal at first change. My second oil change was almost nothing. Do another after 500 more mi and see. I crack open cover also. Sucking it out is a option later once confidence is gained. Also if you mess with the adjuster let it tension on its own. Pushing it is a no no.
Awesome feedback, thanks Steve!Mine was also. I think its normal at first change. My second oil change was almost nothing. Do another after 500 more mi and see. I crack open cover also. Sucking it out is an option later once confidence is gained. Also if you mess with the adjuster let it tension on its own. Pushing it is a no no.
mr. bwok
- Nov 22, 2016
- toronto
- 2017 sr viper ltx
- Marmora
I figured as much, but i had to ask. I pulled the cover and nothing looked out of whack,. I even thought the chain may have rubbed the case as the tensioner picked up slack, but no witness marks. Glad to hear it is normal. Now we just need snow.Mine was also. I think its normal at first change. My second oil change was almost nothing. Do another after 500 more mi and see. I crack open cover also. Sucking it out is a option later once confidence is gained. Also if you mess with the adjuster let it tension on its own. Pushing it is a no no.
