- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
When you guys change the oil, make sure you pull the gold 90 degree elbow out of the bottom of the tank as well and clean the screen area on it with some carb clean. The past two sleds I've changed the oil in (one at 50 miles and one at 103 miles) it was amazing how many little steel pieces there was on that screen!
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
ScottyR,
Your oil change intervals are way too long. Keep in mind when you reed your BMW owners manual they want you to think their cars are trouble free thats a sales thing. By the time you find engine wear problems due too lack of maintance warranty will be over and then they can tell you that proper maintance was not followed and they can charge you big bucks to put a motor in it. CHANGE OIL 3000 MILES. Its cheap insurance! Synthetics maybe a little longer.
danomano
- Dec 12, 2005
- Howell Mi
- www.michiganhomenetwork.com
Oil
Hummm.. Buy a four stroke for low oil maintinance but changing it as often as you fill up a two stroke??
SledFreak
- Feb 7, 2005
- Ontario. Canada
Not even close.......
easylord
I thought the reason for not using Synthetic for break-in was that it is too slippery and the rings will not seat properly. Switching later if thats your prferance. Even if I'm wrong; what could it hurt.
Srxspec said:When you guys change the oil, make sure you pull the gold 90 degree elbow out of the bottom of the tank as well and clean the screen area on it with some carb clean. The past two sleds I've changed the oil in (one at 50 miles and one at 103 miles) it was amazing how many little steel pieces there was on that screen!
Never checked mine but I sure as heck will the next time. Thanks for the heads up.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Personally I think using synthetic to break in an engine will glaze the rings. Dino oil is the best for breaking an engine in. Then if you like to go to the synthetic after by all means.
- 13K
