twomorestrokes
Although the original hyfax were still in good shape, I replaced them today with a pair of graphite slides. I was worried about getting the wide hyfax through the track windows but thought I'd give it a try before cutting a window or loosening the track. Sprayed the hyfax and window with WD40 and the job was as easy as any other sled I've done. Slipped right through and I never loosened the track tension. Just FYI but probably old news to most of you.
Taz107
- Feb 18, 2005
Thanks, good to know, as I will be doing mine soon, if not this weekend...
How far did you let yours wear down before changing them??
twomorestrokes
Mine were about half way to the line at the rear. Fronts were barely worn. 2 seasons/ 2000 miles.
impalapower
When I changed mine out the window just got stretched a bit and they pulled out, no cutting needed.
twomorestrokes
Yep. It was much easier than I was ready for. Hopefully these graphites hold up as well as the originals...
impalapower
How much more for those over the standard faxes?
twomorestrokes
NytroFIB
Would the slides come out of the windows on my Nytro do you think?
I sweat they look too wide.
I will be replacing mine with yellows this weekend.
I just dont think they will fit through the windows.
Later
Later
twomorestrokes
NytroFIB said:Would the slides come out of the windows on my Nytro do you think?
Later
Same track and slides on the two sleds.
pat the rat
- Mar 13, 2006
didnt change my slides yet with 7000 miles on it.still see the line but i did install the anti wear pads about half way through,will change this year
twomorestrokes
It was way too early to replace mine as well. Just figured I'd get it over with since I had the new parts. There was one spot near the rear that was close to half worn but the reast was in great shape.
2 miles and mine were done for. Had to dial in the turbo without snow...
Arctic Express
I just studded my sled and checked the slides over closely. They looked fine with 2450 miles from last season. Got a new set at the Fall Show just in case. WIth the current snow forecast for Michigan going to be tuff to get many miles this season if it don"t start snowing soon.
NytroFIB
I just changed mine yesterday.
Pretty easy to do.
Just did like twomorestrokes said, and took them out and in the windows.
Kinda tight with a litte prying and stretching, I got them.
Also did my handlebar update, wired heated shield plug, and installed a 12v plug.
Sure wish we were all riding rather than having all this time to mod our sleds.
FIB
Pretty easy to do.
FIB
twomorestrokes
NytroFIB said:ISure wish we were all riding rather than having all this time to mod our sleds.
FIB
No doubt!
