hotrodsrx
I just bought a stageIII clutch kit from Ulmer Racing. I've removed the bolt that holds the rollers but am unable to slide the pin out. Are the pins pressed in place or should they just slide out. Is there anything I am missing?
suprfst
You have to loosen the two set screws as well,that hold the pin from rotating.I think they are 2.5mm but im not positive.
