RAMSOMAIR
What studs are those Marc?The stud sharpener works well!! View attachment 154763
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I wonder if it would work on on trackers .iIhave a good set of shapers for my curves .I'll try it
MegabitesWhat studs are those Marc?
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
Megabites
Marc.... Does the Biteharder tool fit inbetween the doubles or did you have to remove one of them to be able to sharpen the stud points properly....?
Also which Biteharder tool the standard one or the professional grade?
Rob
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
You have to remove 1 of them. I have the standard and I've sharpened my 144 studs a couple times and its still working fine.Marc.... Does the Biteharder tool fit inbetween the doubles or did you have to remove one of them to be able to sharpen the stud points properly....?
Rob
no1b4me
- Dec 31, 2016
Excellent... ThanksYou have to remove 1 of them. I have the standard and I've sharpened my 144 studs a couple times and its still working fine.
Dr. FeeLGooD
Turboflash
- Mar 18, 2019
- Southern MN
I'm also a cheapskate but sometimes it's because there's nothing on the market that I think is good enough. So I make/build my own.
For example, my belt guard is full-circle wrapping all the way around the back too. Most on the market only cover front and stop at the two bolts on the caliper housing leaving the back open. (Older pic).
ssgzag15
Poor mans CAI, aluminum coil stock and gorilla tape
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I have used black adhesive either tape or carbon fiber Decal to cover prior hack job Mirror mounts on my Apex. I bought used and the prior owner had these terrible uselessly mounted mirrors on the side panels. Totally destroyed the Stock decals.....so after staring at it forever I decided I could continue some lines of black and maybe it would look ‘OK’. Well until I pointed the repair out no one had noticed it. New decals were >170$ per side, Black taper- 5$, that’s Cheap all the way to CHEAP SKATE.
Oh ya on my VIper, my nephew had a ‘Boo Boo” and ,bent and scraped a portion of the paint off the after market ‘cool’ bumper, so out comes the ratchet straps, dead blow hammers =>straight and Carbon fiber Decal and Black tape-in this case Electric tape stretched just right is the perfect match, I cant see it and no one has ever commented to me. I have to study and feel to find it. Again CHEAP.
Dr. FeeLGooD
Not my Sidewinder, still waiting for parts on that. Did a tail light hack and bolted this on. Was a box for old obsolete equipment that I cut down to size and re riveted it back together. Cheap and effective . Doesnt melt and things inside do not freeze. It is ugly but I am a cheapskate lol. And good storage is hard to find for a Nytro. I have about 2000 miles on this box, including a couple roll overs.
- 12K
