TRiGGeR605
Should you warm up the sled before checking engine oil?
I ask because I checked my oil level last night after running it for about 10-15 mins and it was right at the full mark. Then today I ran it for a good 20- 25 mins and checked it and now its right to the top of the H mark well above the full line.
s1d3w1nd3r1480
yes, per the service manual it says to run it 10-15 minutes then check the level. Also make sure when you are checking the level you are not screwing the dipstick in. I usually just run it until the oil tank is warm to the touch about halfway up where the oil level is
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
The oil will read low until you let it warm up. This year I changed my oil and checked it without warming it up and when I had little over 3 liters in it it was barely registering it on the dipstick. I even checked under the sled to make sure that it wasnt leaking! I remembered then that I had to let it warm up.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Try and avoid being too thorough and add more oil than needed. If it above the line, it will create a mess by snorting oil in the air box and create a brutal mess.
Then you gotta pull it off and clean the filters and wipe it out.
I try and error on the side of leaving it just less than the line.
MS
MS
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
Found mine works best when it is just below the full line. Right on the full line and I get a mess. There are several posts about this .
