I am cleaning my jets for the first time is there a hole all the way through the pilot jet? I have cleaned the ones on the side but need to know if there is one all the way through the pilot. The o rings look to be in rough shape should I go with new ones or just leave them out. It is a flat lander 121 track sled.
I have read the tech pages and it does not really say if there is a hole all the way through the pilot jet. I am thinking there must be.
Len Todd
And, you'll want to replace the O-Rings.
Len Todd said:And, you'll want to replace the O-Rings.
I read a post where LB said they are only needed for mountain sleds this is a flatlanders sled so I took them off and left them off. All of the pilots were plugged so I finally seen the hole through the pilot jet. Put her all back together she fired up right away and it is purring like it should on idle.
Found it check it out if you like.
http://www.ty4stroke.com/viewtopic.php? ... =pilot+jet
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Yes you need to see all the way through. Looks liek you got that figured out. good job!
Turk
Tech Advisor
Pilots are usually the culprit as they have such a small orfice. They plug super easy.
Leave the o-rings off, I have been riding that way for 3 years with no problems. They are to keep gas down by the main jet when sidehilling.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
A few weeks ago I cleaned the carbs on all three of my sleds, there is a hole thru the pilot jet however it is not hollow, there is a cross hair in there. You can see light thru it when clean, but you will not be able to run a wire completely thru it. My wifes sled last year would not idle down when comiing to a stop, since the season was almost over I waited to do anything about it. So when we rode last weekend with the fresh clean carbs it purred like new.
TopGunnSRX
Be careful when cleaning, I just did the ones on my dads RX and one of the needle guides fell out of the bottom of the carb when i took the main out and i didnt even realize it. Sled ran like crap, but luckily i found it laying on the bench runs fine now!
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
03RX1-ER-LE said:A few weeks ago I cleaned the carbs on all three of my sleds, there is a hole thru the pilot jet however it is not hollow, there is a cross hair in there. You can see light thru it when clean, but you will not be able to run a wire completely thru it. My wifes sled last year would not idle down when comiing to a stop, since the season was almost over I waited to do anything about it. So when we rode last weekend with the fresh clean carbs it purred like new.
I have never seen or heard of a cross hair in a pilot jet. I have done mine and my Son's carbs so many times, I could almost do it with the lights off....
I used a tool that is used for cleaning torch tips.
What ever you saw in there, should not be there.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Cross hair may not be acurate, there is something in there that is part of the pilot. Possible venturi or ? I could see something in there when held up to the light, when I ran a wire in there it did hit what ever was in there 2/3 of the way in one end. It was like this in all 4 carbs pilots in all three sleds.
Len Todd
Thought were were talking about the other O-rings (i.e. under the plastic cap.) Have not had to get down far enough into my carbs to even eyeball the o-ring under the jet, on this sled.Sled Dog said:Len Todd said:And, you'll want to replace the O-Rings.
