Clock stays at 12:00AM
Epicsw
Fort Atkinson
2017 Sidewinder
I have set the time on my clock several times and it always resets to 12:00AM at some point and it also never changes to reflect minutes going by. I rode for 15 hours and it stayed at 12:00AM. And, no, the battery has not been disconnected at any point which I would expect to cause such a thing.
Anyone else seen this?
Never but obviously something is broke. Turn it in to dealer.
I'm assuming this is something that has just started happening? Everything was fine with it last year? Have warranty take care of it.
I wonder if a froze power relay would act like disconnecting battery? Sure hope someone makes Solid State setup soon either way.
do you have an antilag on it?
That could be the problem. Once the power is lost it will go back to 12 and stay there. Could also be a problem with the gauge.
Mine has had the same problem since last year taking it in for service today gonna have it checked out
mine does the exact same thing
As soon as you remove the hood and unplug the connector your clock goes back to 12:00 and if you don't reset the time it will stay at 12:00.
Noticed the same thing
