bradthebest
is it normal for the yamaha clutch to make a humming vibrating noise at certain rpm's . its loud and annoying , certain rpms it doesn't do it and others it does .
Ironmanstl
Clutch has been loud since day one.
Think its pretty common
bradthebest
i just find it strange that at some points its perfectly quiet and others it rattles.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Ya mine too. Its gota be the harmonics of the motor.. None of my other triples or my turbo Apex did it though...
Mountaintech
It was a problem with the Vector too. After talking to Tom Hartman I would have to agree with him when he says the culprit is the splined coupling of crankshaft to output shaft. Putting a P-85 on a Nytro does not solve the problem.
Summitseeker
- Sep 14, 2009
My clutch was brutally loud. I read a thread on SnoWest about having the spyder gear shimmed. I had my dealer install the shim. It is significantly quieter but still not as quiet as any other sled I have owned. The shim was about 2 bucks but an hour labour to do the install.
Mountaintech
Summitseeker said:My clutch was brutally loud. I read a thread on SnoWest about having the spyder gear shimmed. I had my dealer install the shim. It is significantly quieter but still not as quiet as any other sled I have owned. The shim was about 2 bucks but an hour labour to do the install.
I know what you're saying. The splined coupling has its benefits but the noise is a pain in the #*$&@. Doesn't seem to affect the clutches. One more thing that could use improving on the Nytro. Seems very "un-Japanese".
Muleskinner
The floating secondary does a lot to minimize belt offset problems. Leads to a more efficient power transfer (less friction and heat). Give and take I guess.
WolfOne
If you are talking about the metallic and rattling noise it comes from the external spacer/shims on the main bolt of the secondary.
They are free to move but hits each other and make noise.
I put a small piece of elettric tape to keep togheter the shims but leaving them free to move togheter.
The noise stop.
I'll take a picture and post it.
Ciao
The noise stop.
Ciao
..SNAKEBIT..
the noise I hear is coming from the primary area,
not the secondary!
not the secondary!
bradthebest
WolfOne said:If you are talking about the metallic and rattling noise it comes from the external spacer/shims on the main bolt of the secondary.
The noise stop.
Ciao
mine seems to be coming from the primary . i could be wrong though , i'm looking forward to a picture .
Mountaintech
It's the primary. Take the secondary off......and it's still there. Then take the primary off and hear how quiet it gets. Quick revving too!!!
mjaremko
Suspended
love to see that photo...............
Mountaintech
The noise stop.
Ciao
WolfOne, hows the snow over there?
WolfOne
bradthebest said:mine seems to be coming from the primary . i could be wrong though , i'm looking forward to a picture .
sorry I was thinking about secondary.
on mon or thu i'll post the picture
may be it will help someone
ciao
