Banjo Man
- Nov 5, 2012
- Lake Barrington Il.
- 06 Vector GT. 15 Vector Ltx . 14 Vector Ltx
Have an 06 Vector GT with a slight rattle but cannot tell if it's the clutch or the cam chain tensioner that I know is a problem with these sleds. Any help is appreciated.
canadianhunter
Before having tensioners changed I found the rattle was worst at cam chain area on right side of engine using a mechanics stethascope.
12SN33
On my 2006 Vector Er, I removed the clutch and ran it and the noise was gone.
When do you hear the rattle? If only at idle its probably the infamous 3 cyl clutch rattle
MadMax
X 2. MM.steiner said:When do you hear the rattle? If only at idle its probably the infamous 3 cyl clutch rattle
- 75K
- Sticky
- 105K
