clutch set up for 2001 srx 2 stroke
Slayer
North
Canada
2018 Sidewinder MTX LE 163, 2001 SRX, 2004 RX1
Hello, I am wondering if someone could get me into the right direction for a snow drags clutching set up on my 2001 srx triple?
8bu-00
W-w-w primary spring
51-43
Green secondary spring
Thanks for your input DMCTurbo, most appreciated. Do you or did you run this set up on an srx in the past?
Ok wonderful.
I suppose you had very good success with it.
Just to give you some more input to figure out if it will work for me as well:
We can't use studs in the Yukon or northern BC on the drag races. I am about 240 lbs clothed up, 6 foot 2. Elevations we run the drags is usually about 2500.
Also could you recommend a place where I could source these clutch items you recommended?
They are all yamaha parts. The helix came on the apex I believe or can be purchased thru Dalton. You are best to go to the 2 stroke side of TY for more info.
Ok thanks, I will move over to the 2stroke side then.
I do appreciate your input though. Gets me a good start.
Thanks for this. I already found where I can source the parts. We also have an incredible Yamaha dealer ship here in the Yukon, who are really helpful as well.
May I ask you yet what kind of track your are running on your srx for the drags?
odds are back then was most likely stock yokohama.
I don't know what class you're running in, but if you are non-studded, then you'd want 1.25-1.5 lug height. 1.5 is the most that will fit for clearance.
I am opting for the Camso ICE Attak XT. I think that should work well.
