Slayer
- Apr 11, 2017
- North
- 2018 Sidewinder MTX LE 163, 2001 SRX, 2004 RX1
Hello, I am wondering if someone could get me into the right direction for a snow drags clutching set up on my 2001 srx triple?
RobX-1
- Coldwater, OH
You will have better luck posting on the two-stroke side of TY.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
8bu-00
W-w-w primary spring
51-43
Green secondary spring
51-43
Slayer
- Apr 11, 2017
- North
Thanks for your input DMCTurbo, most appreciated. Do you or did you run this set up on an srx in the past?
DMCTurbo
- Nov 12, 2005
Yup. It's been 20 yrs.Thanks for your input DMCTurbo, most appreciated. Do you or did you run this set up on an srx in the past?
Slayer
- Apr 11, 2017
- North
Ok wonderful.
I suppose you had very good success with it.
Just to give you some more input to figure out if it will work for me as well:
We can't use studs in the Yukon or northern BC on the drag races. I am about 240 lbs clothed up, 6 foot 2. Elevations we run the drags is usually about 2500.
Slayer
- Apr 11, 2017
- North
Also could you recommend a place where I could source these clutch items you recommended?
DMCTurbo
- Nov 12, 2005
They are all yamaha parts. The helix came on the apex I believe or can be purchased thru Dalton. You are best to go to the 2 stroke side of TY for more info.
Slayer
- Apr 11, 2017
- North
Ok thanks, I will move over to the 2stroke side then.
I do appreciate your input though. Gets me a good start.
RobX-1
- Coldwater, OH
Slayer
- Apr 11, 2017
- North
Thanks for this input as well, very helpful and appreciated.
Big learning curve for me
Slayer
- Apr 11, 2017
- North
Thanks for this. I already found where I can source the parts. We also have an incredible Yamaha dealer ship here in the Yukon, who are really helpful as well.They are all yamaha parts. The helix came on the apex I believe or can be purchased thru Dalton. You are best to go to the 2 stroke side of TY for more info.
May I ask you yet what kind of track your are running on your srx for the drags?
odds are back then was most likely stock yokohama.
I don't know what class you're running in, but if you are non-studded, then you'd want 1.25-1.5 lug height. 1.5 is the most that will fit for clearance.Thanks for this. I already found where I can source the parts. We also have an incredible Yamaha dealer ship here in the Yukon, who are really helpful as well.
- 29K
