Clutch shield cutting instrument panel
PAvector
Pennsylvania
2014 Yamaha SR Viper
You might want to inspect the inside of the instrument panel where it contacts the clutch shield . Mine is cut 2/3 through. I’m thinking of putting a piece of aluminum back foam heat tape to reduce the damage.
I used a channel locks and bent the clutch guard down about 3/4” in down about a 1/4”
Hey OP - Off topic - but no issues encountered with your spare belt tie wrapped there? Thinking about doing the same after seeing your pics, so I can free up some room in my rear bag. Thanks in advance!
I don't believe mine is having that issue, but a quick and clean fix would be a piece of car door edge molding on the guard to blunt it. Split hose cheaper, but not as pretty.
I’ve had it there over 10k miles and no issues.
I like the split hose ideal, I’ll look for some thin stuff.
