mx1500
Hey all. Just a quick question. Bought a whole new clutch from yami as I blew mine to smithereens last spring. j have stock nytro weights and black vlue black spring in it now. Whats everyone running for weights or clutch kit. Would heavier weights and spring mack it cat walk more? Top end isnt a concern
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Ulmer Racing, Schmidt bros racing, Heel clickers drag N flies or 2 speeds are probably the most popular on here. I got a Ulmer kit this year after trying out some others the last few years
YamBam
Did you run Schmidt Brothers clutching? If yes, how was it? I am running stage 2 this year.
Pstn head
Does the Schmidt stage II really give 5 to 10 mph top end? Also how is the mid range compared to stock ? I'm considering that clutch kit but not quite convinced.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
No I haven't tried the Schmidt kit but all the guys that have it seems to like it.
Dodge Ram
I have SB and love it.
ctp1528
Put the SB on last year 2010 rtx se the thing flys. Chris stands behind his kits and will help you with anything. They all are good but imo his is the best'
herndonp
Love my comfort clutch kit by SB. Its a lot easier loading and unloading off trailer and it rips.
Pete
Pete
raginyamaha
no exp with others but my SB kit its pretty nice
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
mx1500 said:Hey all. Just a quick question. Bought a whole new clutch from yami as I blew mine to smithereens last spring. j have stock nytro weights and black vlue black spring in it now. Whats everyone running for weights or clutch kit. Would heavier weights and spring mack it cat walk more? Top end isnt a concern
What are you running for gearing? If you want to be catwalking and top end isn't a concern if you don't already have a 19t top sprocket start there!!
I am running SBR stage II and love it. Big improvement over the DNF kit I had before.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
revster said:mx1500 said:Hey all. Just a quick question. Bought a whole new clutch from yami as I blew mine to smithereens last spring. j have stock nytro weights and black vlue black spring in it now. Whats everyone running for weights or clutch kit. Would heavier weights and spring mack it cat walk more? Top end isnt a concern
Revster what do notice the most for change(s) from DnF's to SBR kit?
mx1500
As far as I know its all stock. Stock weights and gearing.
nytrorider28
- Nov 14, 2010
- Marion, IA
- 2014 Yamaha SR Viper LTX
2007 Skidoo MXZ 600 SDI
Past:2009 Yamaha Nytro
Really Like my SB clutch. All over gains. More so low, and mid. I have over 3500 problem free miles with his set up. Also, would say to Chris is awesome to work with
YamBam
Had SBR kit installed this summer. Have not run it yet. Soon and very soon plan to ride.
revster
- Aug 18, 2004
- La Salle MB
canoehead said:revster said:mx1500 said:Hey all. Just a quick question. Bought a whole new clutch from yami as I blew mine to smithereens last spring. j have stock nytro weights and black vlue black spring in it now. Whats everyone running for weights or clutch kit. Would heavier weights and spring mack it cat walk more? Top end isnt a concern
The DNF was really hard to tune. I messed with it for a while changed springs chatted back and forth with Turk but couldn't get it to do what I wanted. I wanted quick reacting clutches, quick to the power band and quick to backshift. My DNFs were very inconsistent, in some snow I'd be under reving then bouncing off the rev limiter on the hard packed. I couldn't find a happy medium.
Then I wore a flat spot in my DNF weights to they were garbage.
The SBR kit made a huge improvement to my sled. I can easily go from powder to hard packed and the clutches perform well in both. ...and it worked awesome in the mountains!!
