Depending what you want to invest in total cash you can do it numerous ways.
Option 1: Set it up to rev 10,200 or so with no nitrous (you will give up a little performance) and let it run 10,800-11,000 on the nitrous.
Option 2: If you're only going to use nitrous out on the lake then you can swap helix/spring and have optimum performance for both, but if you try to use nitrous with the trail helix in it will hit the rev limiter.
Option 3: Get setup with a PCIII, Ignition Module, give me your sleds serial number and I can raise the rev limiter to 11,700 rpm. Then you can clutch it at 10,800 off the nitrous and just let it rev on the nitrous.
