phazermtxrider
i just found a 159 for a good deal so i got it, now i know ill have to down gear and clutch it, but how much?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Stock 17/41 is as low as you can go. The Phazer based venture has a 45 tooth lower gear so that chain and sprocket MAY or MAY NOT work. I haven't gotten to look at the chain case on one yet. I haven't seen anything lower than 17t for the top either. Looking at the alternate drive setting on the parts list shows 4 different upper gears, 4 lower gears, and 2 chains. The list doesn't give the teeth count though. We know the uppers are 17/18/19/20.
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
I have a 151 on my phaser and I have a 17/41 on it and the sled pulls perfect the chain case should have enough room if you go with a bigger bottom gear but I think the 17/41 will turn that track
Lowedog
I went with a 46 on mine with my 153. With the 3" pitch drivers clutching is about spot on.
