Looks like your belt never sees the top half of the sheaves. You could gear down a LOT
ArcticRider
- Nov 19, 2018
- Above the Arctic Circle, Alaska
- 2016 Yamaha Viper STX-DX 146
2021 Vk 540
Ok, ive got 4500 and its the first time ive blown the dust out. WoopsI clean my clutches every 500 kms or so with brake cleaner.
Well the secondary cam button is intact.
Would like to see a pic of the primary clutch weights, do u know how to remove the cover?
ArcticRider
- Nov 19, 2018
2021 Vk 540
C
Nope, can i remove it with out pulling the primary off?Well the secondary cam button is intact.
ArcticRider
- Nov 19, 2018
2021 Vk 540
I did a ton of hauling 1000 lbs loads the last two winters. With our snow conditions i rarely go over 60.Looks like your belt never sees the top half of the sheaves. You could gear down a LOT
YukonMP
- Dec 25, 2014
- Yukon Territory
What do you guys have to say about the picture of his primary in post 12, something going on there I think.
Yes, but remove the main bolt first.C
ArcticRider
- Nov 19, 2018
2021 Vk 540
I
went out for a little ride and it did seem better after a little cleaning and a lot of blowing the dust. But still isnt running smooth like it should.Yes, but remove the main bolt first.
this could use a scrubbing with a scotchbrite pad as that looks like a lot of residue on that clutch. is there usually frost on your clutch in the morning when you start your sled?
well it did get better with blowing it out but now it sounds like you need to pull the main primary bolt and pull the cover off of the clutch to pull the spring out and make sure everything moves smoothly.
ArcticRider
- Nov 19, 2018
2021 Vk 540
Ok. Is there anything i should know. Take the primary bolt off then remove the screws. Anything special with the spring or anything else i should know?this could use a scrubbing with a scotchbrite pad as that looks like a lot of residue on that clutch. is there usually frost on your clutch in the morning when you start your sled?
aproudcanadian
- Dec 18, 2016
- new brunswick
- 2020 ski doo 900t x
There will be some spring pressure but make sure u mark what position cover is in when u put back together so it’s balanced
let the screws off evenly and mark ing the clutch cover with a magic marker is not a bad idea. they are marked on the back side with an "x" that is right in the casting on both parts.
as long as it is a stock style spring you can hold the cover on with your hand to get it back together. if it has super torquer/heelclicker clutching, you need 3 longer bolts to get the spring compressed enough to start the factory bolts.
while it is apart make sure everything moves/rotates smoothly and there are no lines on weights or rollers. the clutch cover should slide smoothly without the spring in as should the outer sheve/face before you reassemble it.
ArcticRider
- Nov 19, 2018
2021 Vk 540
Oh there's your problem. See those big grooves in the weights.
I can't see the rollers, but I would think they should be changed.
You would really benefit from much lower gearing if you have the chain case apart sometime.
