yup, i agree. it at least needs weights and rollers. new primary spring would not hurt it either.
might be time to talk to the guys at thunder products for a clutch kit better suited to what you are doing with the sled as that changes most of the parts you need to replace.
ArcticRider
- Nov 19, 2018
- Above the Arctic Circle, Alaska
- 2016 Yamaha Viper STX-DX 146
2021 Vk 540
Ok, would you mind giving me a shot for shot description on what i need and what i need to do?Oh there's your problem. See those big grooves in the weights.
I can't see the rollers, but I would think they should be changed.
ArcticRider
- Nov 19, 2018
2021 Vk 540
ArcticRider
- Nov 19, 2018
2021 Vk 540
So, your saying i dont have rollers? I just not sure what you all are sayingyup, i agree. it at least needs weights and rollers. new primary spring would not hurt it either.
Number 26 in this parts diagram.
I can see in your picture that the weights have major grooves which cause them to not function properly, and create the issues you first described.
https://www.cyclepartsnation.com/oemparts/a/yam/56264d3c87a86602c84a3d65/primary-sheave
where the bolt is at the tip of the arm at the bottom left is where the roller is.
the guys at thunder products will sell you all the rollers, weights, springs and helix for your application. if you talk to nospro or shagman on here (owners of thunder products), they will send your weights loaded for your style of riding witch makes the sled perform better. done that a few times on sleds and was happy with results.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Got your email and yes....we will take care of you and get your sled running the way is should.
ArcticRider
- Nov 19, 2018
2021 Vk 540
How does that happen to the weights?![]()
From staying at a steady speed, and certain rpms the harmonics of the engine wear the weights
like 74nitro said. i have seen ones with the line at idle.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
I will add belt debris and clutch wear also adds a factor to these weights notching like this.
Just installed the Thunder Products Big Venom kit on my Viper. What a difference ! Much smoother, a lot more top end. Very happy with the results !!
ArcticRider
- Nov 19, 2018
2021 Vk 540
Awesome, i got stock weights from them and will send it in for a rebuild in the next monthJust installed the Thunder Products Big Venom kit on my Viper. What a difference ! Much smoother, a lot more top end. Very happy with the results !!
2015ViperMTX
- Feb 20, 2019
- Iowa
- 2015 viper mtx
how is the acceleration /responsiveness in the low and mid range? Does it pull harder from a stop than the stock clutching? I’m a boondocker I don’t care about top speed, but it seems most people’s goal is top speed with these clutch kits.
ArcticRider
- Nov 19, 2018
2021 Vk 540
Just put on those used stock weights from thunder products and that seems to have fixed it! Been trying to figure this out for a year. Looks like i will still want to sens it in for a rebuild.
