CJC2014
- Jan 21, 2025
- Holland, Michigan
- 2014 Yamaha SR Viper XTX
I am currently riding a 2014 SR Viper XTX that had a turbo kit installed. Love this sled. However, I am having issues with the headlight, taillight and hand warmers. Trying to figure out if it is one issue or multiple. Here is what's happening.
The headlight is stuck with the high beams on.
The taillight only has brake lights.
Handwarmers don't work at all.
Does anyone know if the taillight is wired in with the switch system that operates the hi/lo beams and hand warmers on the handle bar? Figured if it was then my problem is that. Or if potentially its all individual issues. All three things went out at the end of last season and forgot about the issue until this years ride.
I've checked the fuses for the three but not relays. Thanks in advance for any insight.
Did this just happen in this nasty cold?I am currently riding a 2014 SR Viper XTX that had a turbo kit installed. Love this sled. However, I am having issues with the headlight, taillight and hand warmers. Trying to figure out if it is one issue or multiple. Here is what's happening.
CJC2014
- Jan 21, 2025
- Holland, Michigan
This happened at the end of last season so and hasn’t worked since.
I would check the relays for corrosion and check the wires under the fuse block for warn areas.
