nytroman20
2008FxNytro said:Turk said:Toss that silver secondary spring in the garbage can & use the stock pink
They gave me the spring with the helix. so run the stock blac spring with pink dot, with their helix?
What do i do to get more RPM, add or subtract weight and where?
Try setting your secondary to the 6-3 position, this usually raises rpm
nytroman20
I cleaned my clutches lastnight and when I had the secondary apart I noticed that the helix had rough edges where it slides on the buttons... So I took fine sand paper and smoothed it out. I tried it lastnight at al toms and it didn't seem to do it.... This was the factory helix. Ill see if maybe that was the problem.
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
nytroman20 said:2008FxNytro said:Turk said:Toss that silver secondary spring in the garbage can & use the stock pink
I did do that. conditions havent been great since i have. seemed to get some more rpm out of it but didnt seem to pull as good. couple guys told me this is really not a good way to do it, and that it will mess with the backshift also.
nytroman20
Leave it at 6-2.... What if u were to put 1 bolt and washer mid and the same in the tip... Leave the od empty?
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
yea im gonna go back to 6-2 or 6-1. idk what doing that to weights would do. im a clutching rookie. it seems most are leaving center empty. turk told me i may need two washers in tip i believe so i may try it. idk if this would raise rpm or not though
nytroman20
Wouldn't more weight drop your rpms? If that makes it worse don't put any washers in the tip.
stock
the more weight you add will pull rpms down. the tip has more to do with rpm at full shift. closer to the pin has more to do with lower shift rpms. The secondary should be tuned for backshift ,need enough spring to keep belt from slipping on clutch . Best to check for heat on both clutches cool to the touch means they are not slipping. Hope this helps
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
thanks STOCK, that def helps, gonna run stock secondary spring at 6-2, and check it. i have vented panels so clutches should stay pretty cool. if need more rpm ill take washer out of tip and try it.
