lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
Looking for any suggestions regarding Clutching, suspension etc for the 660' race. I'm currently running TD flash Max17 with 2.5" Turboforce exhaust, CAI. I have the Dalton Green/black in primary and Orange/black in secondary with Dalton quick adjust weights. I can't fit anymore weight in current primary weights. Still over revving slightly ( 9000-9200rpm).
Anyone with racing experience? Any tips are appreciated.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
What drags you going to? Its hard to get guys to release what works. Read all posts about suspensions, belts, and clutching. Get out on the snow and try different set ups. Don’t make to many changes at one time. I have read so many posts That I don’t even know what to try. I am new to trying drags myself.
lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
I'm just doing the local one in North Western Ontario. Dryden, Ignace and Red lakeWhat drags you going to? Its hard to get guys to release what works. Read all posts about suspensions, belts, and clutching. Get out on the snow and try different set ups. Don’t make to many changes at one time. I have read so many posts That I don’t even know what to try. I am new to trying drags myself.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Ya really gotta give yer entire clutch setup so we know what ya got 2 work with.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
Would assume QAY-70 if he is fully loaded already. No expert but would DTAY-1 not have enough weight for that tune?
lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
Stock primary, secondary and helix. Dalton springs with green/black in primary and orange/black in secondary. Secondary spring set to 6 and 1. I have the Dalton Dtay-1 quick adjust for primary weights and they are loaded up with 82gramsYa really gotta give yer entire clutch setup so we know what ya got 2 work with.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
8jp belt?
What studs and how many?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
strap the suspension down tight, you want as little ski lift as possible. Drill new holes in the limiter straps and get low. You need good traction tho.
lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
8JP belt but I'm going to try the xs825strap the suspension down tight, you want as little ski lift as possible. Drill new holes in the limiter straps and get low. You need good traction tho.
No studs...I'm guessing that crucial for drag races
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea pretty much
lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
Thanks for the advice.Yea pretty much
What does the helix angle affect? And say going to a Dalton helix, what would that achieve?
