Np. I'm not sure why RM would list a 200 ohm pickup coil here. Maybe that will work, I'm not enough of an expert on electrical components however to answer that.Thank you, I should have my sensor soon and if it is not 5oo ohms I may get you to get me one if it’s not to much trouble.
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Maybe an electrical guru will see the post and let us know. Lol.
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Picked up the sensor today, 500 ohms! Should have my gasket by the end of the week.Thank you, I should have my sensor soon and if it is not 5oo ohms I may get you to get me one if it’s not to much trouble.
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Hey 74 Nitro my sensor wires are not the same colour as originals. Wires are light purple and light green, the directions say if it doesn’t start or backfires to switch the wires. Lol.
You wouldn’t happen to know which colour goes where?
Don't worry about the colour. Just hook them up, and switch if necessary.Hey 74 Nitro my sensor wires are not the same colour as originals. Wires are light purple and light green, the directions say if it doesn’t start or backfires to switch the wires. Lol.
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Set the air gap / installed the sensor, hit the key and fired right up!
Super!Set the air gap / installed the sensor, hit the key and fired right up!
- 26K
