code 30 help
Nytro code 30 = "Engine stops when an oil pressure drop is detected."
Check your oil level, and the float in the oil tank. Next thing is the oil pressure sensor...
Did you overheat it? Theres an oil pressure sensor switch beside the oil filter, follow the wire see if its melted anywhere
Code 30
Check your oil pan to see if it is cracked or compromised in any fashion.
I had mine crack on me a few years ago after coming down hard off a drive way approach.
Also check to see if your sensor by the oil filter is ok.
If neither of those are the culprit, start looking at the oil tank and lines on the brake side of the sled.
Hope that helps.
Kope
Nytro code 30 = "Engine stops when an oil pressure drop is detected."Â
Does the oil level float give the same code as the oil pressure sensor?
