Code 30
Laddy123
Stanley, North Dakota
I just recently did an oil change and my sled is throwing code 30 at me which I know is oil pressure sensor but I don't know what could make that go off. I'm also getting Code 84 which is TORS but I don't know how to fix that either. Any help would be great. Thanks!
Did you change the filer? I think the sensor was unplugged to aid the filter change and was forgotten to get plugged back in, been there, done that.
84, check your throttle cable freeplay.
You might have two units, later models have two. Check your handbook. There's one on the front of the engine. Near the filter. But I do think that you just have to help the oil pump with oil the first seconds after starting it. I usually just blow at bit of air into a plugged oil can. Think that code 67 is a faulty oil pressure unit. Had that once. 85 might be code for oil pressure unit to (if you only have one).
Sorry, I was mistaken. 30 means low oil pressure, 85 is the oil pressure switch. before the oil change it was working properly? (You started the sled to warm it up before draining the oil)
I can't get the inter cooler off as I never have taken it off and I can't seem to get it off no matter what. Any help?
i have had that before after completely draining the oil, and also from rolling the sled to its side while its running. i believe the oil pump gets an airlock n does not want to pump oil. so to get the oil flowing again i'd tip it to its side (but i dont remember which side left or right?) and run the engine and give it gas.
