hi i have a code 23 that is on my sled since i give it its first oil chage i went through the steps to clear the code 61 says 00 but 62 says 1 and i tried up and down on the hand warmers and every time i turn it on yellow light comes on and code 23 is still there any ideas
I'm having the same issue, code 22 & I plug in the sensor. Clear code. Start. Check engine light yellow ON. Shut off. Check codes. 61 = 00 (no codes) but 62 says 1 code... what in the F!? Can't clear the 1. Check engine light stays on.
It's intermittent and only comes on at idle, hit 20mph and Check engine light goes away.
