Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
My buddy ‘s 2019 Sidewinder LTX LE just started throwing a U0132 code. I can’t find it any where re the Sidewinder. I did google it and there was an automotive code that matched relating to suspension. Could it be his electronic suspension? Has anyone had this code? Thank you in advance!
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
In the service manual this code means "Lost Communication with Suspension Control Module." I'd say your guess was good. I'd start with checking the fuse and/or relay.
Wannaviper
- Mar 18, 2014
Thank you!In the service manual this code means "Lost Communication with Suspension Control Module." I'd say your guess was good. I'd start with checking the fuse and/or relay.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Pretty sure there is a common failure or even a bulletin on the iAct control board.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
My buddy got the control modual code also and it needs to be replaced!!! The new modual is on back order for his 2020
Wannaviper
- Mar 18, 2014
Thanks everyone. I guess it’s good news that it’s not an engine issue, but bad news if the fix for it is on back order. At least he can still ride it.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Yes I believe it defaults to the stiffest setting that's all!!Thanks everyone. I guess it’s good news that it’s not an engine issue, but bad news if the fix for it is on back order. At least he can still ride it.
Wannaviper
- Mar 18, 2014
He rode it for 150 miles yesterday with no complaints, but the trails were pretty smooth. Things may change when the trails get roughed up a little.Yes I believe it defaults to the stiffest setting that's all!!
Fleecer
- Jun 13, 2014
- 2019 SRX
It stays at the last setting. If you put on 1/softest and get code, that is where it will stay.
