TheMogulMogul
whupperofwhoops
- Sep 18, 2018
- Rochester NY
- 18 ZR 9000 RR
137” skid. I put in a solid axle 4 wheel kit and now the cogs hit as if they were a different ratio than the track. 8” wheels. You can spin track halfway before the teeth bind on the solid bars themselves (track clips). Everything looks correct, new sled, only change was the big wheel kit (Larson). I can’t figure it out...
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
There is pitch built into the drive sprockets, the track will try and outrun the drive sprockets basically. Its normal. the fourth wheel kit did nothing to change anything there.
Don't worry about it. It will spin freely under power.
TheMogulMogul
whupperofwhoops
- Sep 18, 2018
- Rochester NY
- 18 ZR 9000 RR
Thanks Mike! You are the man!!!
Boston RX1
I have the Larson kit as well with no issues. I also know several people with this kit and they all are working well. Go Cuse!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Same stock track, same stock drivers.....no issue. Easy peezy.
Dan
Dan
- 8K
- 12K
