Looking into buying this 05 RX1 thats been sitting since last January 06'. Cleaned carbs ect... (Tuned up) and it seems to run real good (only 1000 miles on the machine) but we did a compression test
180,185,170,170. Could it be this thing just needs to be run out on the trail and really warmed up from sitting that long?
Travis Moore
The motor has to be warm and the throttle has to be open to get a accurate check..
T
T
mdemmons
- Feb 1, 2007
Not sure how different it is with an '05, but in my '03 RX-1 service manual, it states:
Standard Compression Pressure: 1,450 kPa (14.5kg/cm2, 206 psi) at 400 r/min
Travis Moore
The sled is fine, the gauge is wrong and/or the test was performed incorrectly.
T
T
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
1000 miles its not even broke in yet
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
In addition to WOT throttle and warm motor you have to take off the air filter and lift the the throttle slides manually to wide open, this way your compression test will read higher (correct)
black john
comp
low end of the limet is 179 - 230 is the high end with 206 being the norm . and yes you should lift the slide,s and open the throtale. other wise you will read a lower number.
