hlmrx1
Let her rip, if they put the glue down the way they should then you won't break loose that much. That's also considering you have your skid set right.
monker
WOT from start to finish. Adjusting your transfer affects if you spin or not. Not enough transfer and you'll spin, too much and the skiis lift too high. A lot depends on what you're trying to do. If you want to go as fast as possible, there's a lot to do each time out with the skid making adjustments. If you want to be consistant, you can find a general 'good' spot and leave it there all summer. Once you get hooked though, there's always some 'tweaking' that can be done.
