jameshofo
I'm looking to convert my 09 XTX over to more of a mountain machine and make some improvements along the way.
So what I have so far is timbersled front end and Fox Zero pro shocks
I'm revmoing most of the foam from inside the sled
I've ordered 20 tooth drivers and I'm told stock the XTX has 19-41 gearing
I've installed Simons flexi skis, and a 144" 2" track.
The track has defenitley impoved my hookup but its a lot of work for my sled to plow though the deep stuff.
What I need I need is some help with gearing, should I change the bottom gear? I'm also going for the extrovert drivers and would like to know if an anti stab kit is required on yamaha. I planed to change my extroverts to 8 tooth down from 9. Will that give me more a mountain sled? or should I look into changing out hte bottom gear?
