Coolant temp sensor replacement - sealant
SR Viper
Is there any sealant required? If so, what should I be using.
If your sensor has a sealing washer then no, if it doesn’t have a sealing washer I would use a small amount of pipe sealant with teflon, don’t get crazy with it a little goes a long way
